I am using Microstation V8i SELECTseries 10
Version 08.11.09.919
When I load Civtools the Message Center will say "Civtools loaded" But then I am unable to click on anything else, I eventually have to task manager > end task on microstation to be able to restart.
The only fix I have tried is I redownloaded Civtools but that did not work.
This is happening to other people in my office as well.
Hi Levi,Thanks for supplying those msdebug log files.I took a look at them, and I did not see anything that jumped out to me. I'll let you know if I can find anything further.Note that I was able to reproduce this issue as well using a v8i SS10 build. It seems like this could potentially be a Windows OS issue caused by an update, the OS version, etc.Since MicroStation v8i is no longer a supported version, no fix can be made programmatically on Bentley's side, but you might have a few options since you have a working machine available. First, I would recommend to temporarily freeze all Windows updates to the working machine's OS.Second, compare the Update History on the non-working machine to the working machine (Windows Settings>Update & Security>View update history). Try uninstalling any recent updates on the non-working machine so that the history matches the working machine. Keep in mind, your IT admin may need to get involved depending on your organization's security and procedures.
Answer Verified By: Levi Hitt
That is the issue for sure
All of the troubled computers were updated last week and the one that was still working was last updated 2 months ago.
He has frozen his updates, I do have access to a connect version of microstation that I have used a little bit, (just more use to the old) so this may force me to start using it more often
Hi Levi,Thanks for the update.There are some methods available to make CONNECT "feel" like v8i. Should you need assistance with migrating to CONNECT, I would recommend filing a Service Request online via https://apps.bentley.com/srmanager/ProductSupportIf you choose to file a Service Request, let me know and our team will be on the lookout to assist.
-Jayson P.
I will go ahead and file that request now
Thank you for all of the help!!
Anytime I feel a recent Windows Update breaks something in MicroStation V8i (as the case here), I simply reinstall the latest Bentley V8i prerequisite pack (version 08.11.09.03) - and it usually resolves whatever V8i functionality was broken by the recently installed Windows update. Others recently reported this issue at my company. Without testing, I simply reinstalled the Bentley V8i prerequisite Pack - and the CivTools appears to be working OK in MicroStation V8i (SS10).
HTH
