Hi
back few years - we are asking to cut multiple solid - as i remember it is possible in v8
now in newest Connect it seems not working with new solids or using legacy solids cut.
I mean > select all solids with cutting profile and use cut
Any idea ?
Are you creating parametric solids?
just use slabs from solid modelling
I believe i can replicate the issue.
martinezx said:I mean > select all solids with cutting profile and use cu
To clarify you are preselecting the solids to cut before starting the tool.
The operation works for me if not preselected.
An alternative is to use fence clipping:
communities.bentley.com/.../optimized-fence-clipping
Alternative can works not try yet.
About normal cut but how it works for you if you not preselect solids ? how can you cut multiple by once - i mean not select one by one?
After selecting the first solid you can hold the CTRL key to add more solids to cut.
