How can i lock distance by Ctrl+V value ?
Is it not possible ?
Connect edition
Like this?
docs.bentley.com/.../LocksDialogUnit.html
What i mean Barry
for example you want to draw SmartLine with copy / paste value 527.450
In accudraw XYZ it works > in starting point Ctrl+A ( select all value that is 0.000 ) > Ctrl+V 527.450 > hit X to lock X
but when you switch by M to distance - i can't lock by D this distance
In fact maybe this need some improvement when paste value ?
That's always been that way, instead prefer to use the DX= key-in (or the DI= Key-in if requiring an non-orthogonal angle)
