how do you create raster linestyles?
Im following the manual, but it will not save the linestyle
Can it be a jpg file, or does it have to be a png?
I get this message
Raster components can not be used directly. They can only be used as compound sub-components.When a Raster is used a compound component, it will override the display for screen displayand rasterized printing. The non-raster components will be used unrasterized plotting and inolder versions of MicroStation.
Kirk, see if this blog helps you. https://communities.bentley.com/products/microstation/b/microstation_blog/posts/new-in-microstation-connect-edition-update-7---raster-custom-linestyle?CommentId=9f2629fb-7725-4642-ab47-c56feae348e5
Kirk said:Can it be a jpg file, or does it have to be a png?
both are supported.
You have to create a compound element that contains the raster element and link the compound component to the name.
