Converted 2018 .DWG files into DGN files using Connect version 16. To open in connect solids looks good. To open same file in Microstation in V8i the solids turn into surfaces and no longer render properly.
Can you share the file for review?
CONNECT does have some type of elements that are not supported in V8i but they should show as extended or application elements.
Hi Colin,
I agree with David Trejo-Rodriguez to share the file is important for analysis.
The problem is you share no details, so it is impossible to say whether it is feature or it can be solved e.g. using different configuration or post-import modification of the solids in CE. It would help to share at least screen captures how elements are represented in CE and V8i, both visually and in Element information dialog (key-in "analyze element"), because standard Properties dialog hides some internal details.
With regards,
Jan
Colin Taylor said:as a solid, its a smart surface.
What "analyze element" tells about the selected element? (both in CE and V8i)
Here is the connect version.
Below is V8im not rendering as a solid, its a smart surface.
Is this what you mean?
V8i version
