Hi Everyone
I need to convert multiple DWG drgs in DGN is there any fast conversion processs let me know
Thanks in Advance
Use the Batch Convert Utility
communities.bentley.com/.../batch-convert-utility
Thanks Barry
Is this converter keep intact the symbology (Color, line style,Weight) of dwg file?
Excellent!
Thanks a lot
Yes it should not change anything in the original symbology unless you specify it by providing a remapping CSV file in the Save as DWG/DXF options.
The batch utility is the best way to convert multiple files. Be aware that some type of elements in DWG are not supported in DGN. If you have issues you may need to adjust the settings of how DWG files are opened.
