When I was working in Microstation V8i and added a reference-file it was getting selected directly after I added it into the references.
But when im adding a new reference-file in Connect it doesnt get selected automatically after I have added a new reference; which can be a bit frustrating when working with alot of references.
Is it possible to get it like above in Connect without having to search through the references and manually select it after I have added it?
Hi Tommy,
if you think it is bug, create Service Request to ensure the issue is logged.
If you treat the issue more like "nice to have", post it as new Idea.
With regards,
Jan
P.S. Please follow the best practices and always specify used product including its exact version. There are many "Connect" (which is not "Connect", but "CONNECT Edition", or just "CE") versions, and often it is crucial to know what version is discussed.
Not sure if its any of them, maybe just something in settings I cant find?
Tommy Karlsson said:maybe just something in settings I cant find?
I am pretty sure such setting does not exist.
Okey, thank you Jan for the quick answers.
Tested out myself and can replicate the behavior. Can confirm there is no setting for this. Will have to ask development if this is working as designed or if this is a bug. I noticed if I close the reference dialog and reopen it has the ref selected.
