Hi everyone, I’m Keegan and I work for Nippon Alloys. A client of ours is having issues while installing the latest version of MicroStation on their Windows 10 PC and needs a solution to this ASAP. Does anyone have a quick fix to this?
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
Nippon Alloys said:A client of ours is having issues while installing the latest version of MicroStation on their Windows 10 PC
Why can't the client post that question here? Then we would have more information about the host computer.
Nippon Alloys said:Does anyone have a quick fix to this?
Suppose your car is broken. You call a garage on the other side of the world and ask: "Can you fix my car?" What sort of response would you expect?
Without further details it's impossible to respond to your question.
Apart from the version of MicroStation, what operating system is used: Windows 10, but 32-bit or 64-bit?
have you asked bentley tech support direct?
Lorys
Hi Nippon,Thanks for the post.I would recommend checking out the QuickInstall Guide first to ensure you are following all recommendations.Since it sounds like your issues are urgent, I would recommend filing a Service Request online via our Service Request Manager
Lastly, the Bentley support page can be found here where you can contact us: https://www.bentley.com/support/
Hope this helps!-Jayson P.
