The toggles for "display raster references" and "treat attachment as element" no longer work in microstation connect (V 10.17.00.209) unless i Use the buttons along the bottom of the reference manager. Is there a way to turn that functionality back on?
Please file a service ticket for this. This is just another instance of regressions in Microstation.
--Thanks,--Robert
I am unable to reproduce the behavior. Is this happening on multiple machines?
Good suggestion. It works on other machines. I will submit a support ticket.
Hi David,
I was able to reproduce this on a clean copy of Microstation CE U17.1 on a clean copy of Windows 10. (Virtual computer, kept totally clean for testing Microstation only).
--Robert
We tripped over each other. My computer is a totally clean machine, so the defaults are Microstation's "out of the box" defaults.
