In my Microstation CE U17.1, I can open the key-in tool and type, "active style NoGood". (I do not have a style called NoGood--any name that is not defined causes the error.) Then I hit the "X" at the top right corner of Microstation to close it. Microstation appears to close properly, but then in about 5 seconds I get this dialog box:
I have also seen a different dialog box, which is similar with the options of close, abort, or try again. Usually Microstation will then close out, but sometimes I find it still running in the Windows Task Manager. Someone at Bentley appears to be having a hard time recreating this issue. Is this something with only my three or four computers, or can other people reproduce this?
Steps:1) Open Microstation2) Open the Key-In tool3) Type "active style NoGood" and hit the enter key4) Close Microstation (I use the X at the top right corner.)5) Wait 5 to 10 seconds.
--Thanks,--Robert Arnold
Hi Robert,
This is reproducible. A new defect #1001114 filed on this issue.
Connie Wallace
Answer Verified By: RobertArnold
