How to place different TIF images with the same name in the same location Microstation
I produce TIF images from the same location year over year, then move them into a different position in Microstation. I'm wondering how I could position TIF images produced in subsequent years by the position of the first year images.
Thank you in advance!
Parents Reply Children
  • Not offhand. It's not something I've had a need for. There is a Programming Forum that you can search for posts with similar ideas or example code. People there won't often write the code for you, but they can help you troubleshoot your own. If you do ask for help, make sure to list both the language you would be using and the specific version of whichever software you are using. There have been bugs, fixes and new capabilities added over the years, so version number is important.
    If my suggestion answered your question, could you please click the "Verify Answer" button? In the future, people will search for this same thing, and know that there was an answer to this question.
    Good luck!
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
