MicroStation Configuration using Windows Environment Variables
I am trying to use the windows Environment Variable %USERNAME% in my configuration file(s) but it does not seem to work.  Is there a trick to this? I something blocking it from working?  When I use the %USERNAME% in the configuration that is what show in the configuration dialog not resultant system username that would allow me to point to C:\Users\mlongstreet\...
Parents Reply Children
