I am trying to use the windows Environment Variable %USERNAME% in my configuration file(s) but it does not seem to work. Is there a trick to this? I something blocking it from working? When I use the %USERNAME% in the configuration that is what show in the configuration dialog not resultant system username that would allow me to point to C:\Users\mlongstreet\...
The key-in expand echo $(username) seems to not work for me. But using $(username) in the config did work great.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Check the Message Details in the Message Center
Nothing happening in the Message Details either.
Select $(USERNAME) in the Message Center list and then check the value under Message Details.
Hi Mike,
More suggestions for using Windows Environment Variables: CONNECT Edition - Configuration Tips: Use of Windows Environment variables
Marc
