[CONNECT] Applying an Element Template to a SHP Reference File
I have done this task, "Applying an Element Template to a SHP Reference File", in the older V8i edition. However, I cannot get it to work in CONNECT.
The workflow is posted here: "Applying an Element Template to a SHP Reference File" [Applying an Element Template to a SHP reference file - MicroStation Wiki - MicroStation - Bentley Communities]
Here is screen capture of my current MIcroStation session.
Element Templates are created. 'ZAI22SLP' is the blue line (drawing with the Place Line tool). 'YIA' is the green line (drawing with the Place Line tool). So, this proved the Element Templates are working as expected. However, when the same Element Templates are applied to the Reference Attachments, they do not apply the symbology settings. The dots (hard to see in the image as shown in this post) should be blue (ZAI22SLP) and the curved line should be green (YIA). Save Settings and restarting has no effect.
Any ideas?
Parents Reply Children
