Hello, forum!
In a cell-library model, I have a reference to an external file, and used a fence to create a clip boundary to hide some of it. When I go to place this cell anywhere, the reference in this cell appears unclipped and I see its entire contents.
Is there a way to retain the clip boundary (or clip mask) when placing a nested cell?
Thanks! Hope your days are going well!
MicroStation V8i SS10 v.08.11.09.919
EDIT: It doesn't matter if the reference is from a different file or the same.
EDITED TITLE: From "Clipped or Masked External References Appear Unclipped/Unmasked within Nested Cells"
Why are you referencing an external file and attempting to use that as a cell? Can you not just Fence Copy (clip mode) the content you want to use for the cell?
Our agency adopts the standards and the resources/libraries of another. Some cells they have are full-sheet templates containing their border. We use the same template sheets, but we use our own border. My idea is that if they ever update their cell library in the future, ours would be updated sort of automatically as opposed to having to change the content manually.
Currently we do copy the content over, and then delete their border and slap our's on it, which is easy enough to keep doing. I'm currently updating our libraries and it was a curious idea I had to help automate it a little.
Depending on the amount of cells you would be placing, what you describe sounds more applicable to placing a cell by referencing a model which has 'Can be placed as a Cell' enabled.
Copying in the content in and then your border I would say is better. If you ever have to update, just update the master cell (model) and use the Update/Replace Cell tool to propagate the new version to the existing outdated cells.
Thanks for the replies!
I am creating a cell (not just placing it), and this cell I'm creating contains a reference. (I actually just found out it doesn't matter that it's in a different file or the same.) Some of the reference is hidden with a clip boundary or mask. It is later when I place this cell in another file to use it, the clip boundary or mask within the cell is ignored.
(Sorry, I just wanted to reword that in case it got confusing. Seems more of an unintentional result rather than a "feature", but that's just me probably. Also don't know if it's like this in CONNECT.)
Barry Lothian said:Depending on the amount of cells
It's more of a general question. Amount of cells could be zero; could be many.
Barry Lothian said:referencing a model which has 'Can be placed as a Cell' enabled.
After testing it, it doesn't matter if the referenced model itself can be placed as a cell or not. The result is the same.
Barry Lothian said:update the master cell (model) and use the Update/Replace Cell tool to propagate
That won't work the way I want it to. (Won't be automatic, not like it is if the .)
It’s an unusual concept to want to place a reference file within a cell. It’s not something I’d do myself, and if clips are ignored, it might be an intended behaviour. If updating cells isn’t something you are willing to consider then the only ‘standard’ form of automatic update would be to forget using a cell but instead, for every cell instance, create another reference file. That will give you the auto-update you desire, but might not be an approach you want.
