Greetings,
Is it possible to get the name of a used (nested) external referencefile in a field in the texteditor? If yes, how.I know how to put model and sheet properties in a field in a textbox using "f(x)"; though properties like sheetsize (A0/A1/...) scale,
but unfortunately the name of a referencefile not ....
Thank you for time and trouble in advance.
Jorge
Please confirm Product. / Version being used.
Another alternative workflow if using MicroStation CONNECT Edition is to generate a Report and place as a Table into the design.
The Report can not only filter on if a Nested Attachment, but also if displayed etc
Carl Myhill said:workflow if using MicroStation CONNECT Edition is to generate a Report
Good suggestion!
Jorge Hendrikx said:I could not make it work
Here's a step-by-step article how to write a reference report.
You can, as Carl Myhill writes, create a DGN table from a report. You can also export the report as Excel or a CSV file.
