Please help me this issue, thank you in advance.
I have a list of text and coordinate. How can I place all text into specific coordinate in drawing in the most efficient way?
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
Microstation will fill in that box with the first text in the input file
Answer Verified By: Tuan
in addition if you look at the order option, you screen shot there are several options to match an existing table, in your screen shot you have XYZ T , so if you text table has XYT and your dgn is 2D it will use the 3rd column for the text value, from memory I think there is also an option with TXYZ so your first table example screen shot looks like excel would work if you change it to csv in excel
Lorys
Thank you so much. ^_^
