Hi
I need to find geographic location in design file thruogh text search in design file, can I do this and how?
I need to find places where the text is beginning with VS and locate the text so I can rotete the hit text 90 degres.
Can I do this in Microstation?
I found this by visual search and got it rotated.
But if I want to find next in a huge area, ??
Best regards
Tom
Microstation version used:*
If you are looking for any element you can use the (very old but comprehensive) SelectBy Functionality. It is hidden in CE (maybe because of the outdated interface and way of working...?)
In the settings of that dialog you find also text and textnode searching where you can filter out texts not only by level but also by properties like font and textsize
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v19/en/SelectByAttributes.html
