How to set Display Style for DrawingSeed?
Hello all,
Tested both on Openbuildings Designer 10.09.01.38 (MS 10.16.02.26) as well as ProStructures 10.07.00.79 (MS 10.17.00.209). So I decided this is the best place to ask as it is a Platform/Microstation question.
When I create a Custom Drawing Seed (in this case for a section callout, could be plan view or elevation view as well) I follow these steps: To Create a Custom Drawing Seed for a Section Callout (bentley.com). This works fine, I can control also the display style that is used for the "Clip volume settings" as shown below.
However I would also like to set the display style for the 'View 1' that opens when I create the new model:
I have set this to be the active Display Style in the DGNLIB and used save and save settings. So next time I open the DGNLIB this is the active display style. But when I create a new section, using that DGNLIB as seed, the display style always gets set to (Wireframe Display) as you see in the screenshot above, instead of the custom display style I created.
I tried with another custom Display Style, based on "Smooth" and then this is the style it is set to after creation of callout:
It appears that somehow the active Display Style of the DGNLIB is being read and something is done with it ...
Since I will be creating many drawings/views like this I would like the default to be correct, instead of having to manually change it after creation of each section. The most important issue is that my custom display style is connected with a Display Rule. It's mainly that display rule that is important to me.
Anyone have an idea how to change this behaviour? Or encountered the same and found no workaround?
Parents Reply Children
