Hi Everyone
If you can compare above 2 drg.s you can see 1st drg. is darker than other drg.
there is no weight issue in this but there is some setting to resolve this issue.
but I forgot. Does anyone know resolution for this
The 2nd one looks like it has transparency applied, perhaps according to it's level. But I'm not even sure what these are. DRG? Digital Raster Graphic. Guessing those are DGN sheet models.
this are pure dgn files no graphics no image there. I will check whether I applied transparency to each level or not and let you know
Is it possible that the view attributes for one file has Line Weights ON, and the other file as Line Weights OFF?
MaryB
Weight is on in both the files
Thanks MaryB
It would be helpful if you could supply details for the software and version being used. The image you provided is also quite small and difficult to view. If you could supply some larger screen captures and possibly the DGN file, we could then check what might be the cause of this issue.
