Per the recent "Digital Currency" newsletter issued by Bentely - 13 October 2022. there was an article about Bentley Configuration Explorer and its availability.
i have downloaded this and looking to use it, however it appears that you can only run the configuration review against workspaces / worksets within the standard Bentley deploy location - C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces.
How do you get this to work for a configured location outside of the standard delivery location ? or is this not possible ?
Many companies run their configurations outside of the above location so would make sense that you could navigate to this location within the Configuration Explorer tool
Glad to help, Eduardo.Feel free to reach out if you need assistance in the future.You can file a Service Request with us anytime via the Service Request Manager: https://apps.bentley.com/srmanager
-Jayson P.
Will inquire with development on any planned updates. Any announcement on a new update should be made on our announcement forum.
If I now start the config manager, the wrong workset list is read,I have different workspaces, but only the last listed is loaded,if I change the workspace, the workset list is not changing any moreso I can not load the correct variables to examine the configurationworking with the imported debugging *.txt file give too less possibilitiesI really need an update for the configuration explorer
regards RikOBDu10
Hello Rik,If you are continuing to experience issues, I would recommend you file a Support Case via the Bentley Support Portal:https://bentleysystems.service-now.com/csp
-JP
Is configuration explorer being updated to work with MS 17 and MS 2023? Currently with MS 2023, it throws an exception at line 0
