Is there a way to convert cell libraries from 3D to 2D. All of the cells in the libraries are really 3D (i.e. flat), and should just be top-view 2D cells. I thought I could use Batch Converter somehow, but I don't see a way.
Ultimately, I would like a file with the same models/cells as the original 3D models, but in 2D.
I did export a “flat” 3D symbology lib to 2D in an older version once But i did not notice any performance difference. I find the 2D display is better. Especially if you want use the lib with the cell selector, as I still some times do. It is somewhat outdated but I it is still the only way to very quick generate a screen menue of libraries, right?
