I have a larger file that produces an "Error creating file ..." when I try to save it as dwg.
After a lengthly search breaking down the file I found that a ":" colon in an item is causing this.
After deleting the colon in the item text .
I attach a file with the same symbol with and without colons
Neues 5OG Teil2_2_unten13b2a.dgnNeues 5OG Teil2_2_unten13b2a2.dgn
I faced this error for two files.
So it is likely not the item type value problem.
Hi, funny that it worked for me once. Now not any more. I have now uploaded the whole original file and filed an SR just a few minutes ago ...
How would you figure out what is causing the issue?
Need help for the selected function? Click into the "Toolsettings" dialog and press F1 For Screenshots try Win+Shift+S on your Keyboard - I am using "ScreenRecorder" for Videos Brauchst Du Hilfe zur gewählen Funktion? Klicke in das "Funktionseinstellungsfenster" und drücke F1
I encounter such errors quite frequently. I'd say about 20% of my files won't save as DWG (R12) with MSCE 16 German (was the same in 14 and 15 - my colleague uses 17, same thing there) while there's almost never an issue when saving these in V8i.
In V8i SS4 I can convert to DWG without trouble, right. Yet I loose the items with the existing cells - and the labels are just texts not even tags... (? or am I missing a OPTIONs setting?)
Reproduced the error. It worked fine by dropped this Text Node to Text then saving to dwg.
Do we have a bug number?
Thanks.
