Is there a dialog box for changing linestyle scale for custom lines or a way to see what scale is applied to a linestyle. I have managed to get the key in for change linestyle scale to work but find it a bit clunky to use when you do not know the present linescale.
Microstation connect 10.16.03.11
Tony
Never mind I finally found it in the extended properties under line style properties. I cannot believe that there is not mention of this when I search for linetype scale.
Properties is really the best way to change scale for linestyles that were not place ByLevel. If they are placed ByLevel, the Level Properties Dialog has, on the second tab, a place to change the linestyle scale level-wide.
MaryB
Or use the tool to set it what want?
