I just started learning how to use ACS, but when I reset the ACS back to global origin the XYZ are still showing an angle offset, like X=230 deg. when it should be 0 deg. How do I get back to the default XYZ's = 0 deg.? The coordinate symbol is showing in the proper direction, that is XYZ directions indicate it's back to normal. Is the ACS still active, if so, how do I reset and delete the 'unnamed ACS' to get back to default Coordinates?
Peter Ramirez said: the XYZ are still showing an angle offset, like X=230 deg
Can you give us a screen shot to demo what you mean? And providing your test DGN file here can also help.
I just did the Reset to Global like below pic shown. After this, all XYZ value are reset to 0.
Thanks for your response. I have tried resetting back to global but nothing changes. Here is a screen shot, note that Accudraw = 0 deg. but Line Dialog Box = 230 deg.
Peter Ramirez said:note that Accudraw = 0 deg. but Line Dialog Box = 230 deg
Line angle has nothing to do with the ACS (which is clearly shown to be at the Global default values). If you want the Place Line angle to change, then you simply change the active angle value, either in the dialog or using the keyin e.g. AA=0.
What does look wrong in your screenshot is that Length and angle values should not be visible unless the checkboxes are enabled.
Right click on the area where you have column names like Name, Origin X and enable Rotation.
Change in Rotation manually to 0 by typing.
Not sure what you are saying. I draw a horizontal line that should be 0 deg. But it is stating 230 deg in the dialog box. But the Accudraw angle is 0 deg.
