Hello
Microstation V8i
i am trying to move tool boxes on my screen however i have trouble with top of box being off the screen.
For example, i press the place text command and the text editor box is half off the screen. So you cant grab the blue ribbon at the top of the box to move
the text editor box centrally into the screen.
The following wiki may be of help, if not you could also try restoring MicroStation settings
Answer Verified By: Garry Farquhar
Change you monitor resolution to be 800 x 600. Then you should see the entire settings dialog. Drag it to the center of your screen then revert the resolution. Once done, make sure you Save Settings.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
