BEHAVIOR
Using the "Change Element Attributes" tool with specific library attributes changes any/all elements to Default level & ByLevel settings. SS10 is out of support and I'm looking to understand, resolve, and prevent this behavior from reappearing. (Attached example screen recording.)
CONTEXT
This user (mainly remote) experiences this behavior both while working remotely (RDC) and also in office. This is the only user that reports this behavior.
ATTEMPTED FIXES
SOFTWAREPowerGEOPAK 08.11.09.918
SPECIFICATIONSDell Precision 3630 TowerOS: Windows 10 Pro; Version 21H2; OS build 19044.1766CPU: Intel Core i7-9700 @ 3.00 GHz, 3000MHz (8 Core, 8 Logical Processors)RAM: 32 GB, 2 x 16 GB, DDR4, 2666MHz, DIMMGPU: NVIDIA Quadro P2200 w/5 GB GDDR5XSTORAGE: M.2 2280 512GB, PCIe x4 Gen 3 NVMe 1.2.1
Hi Josesph,
One thing in particular I can see is that you have Template enabled, and it might be worth checking to see if the same behaviour is still evident when that attribute is disabled.
Answer Verified By: Joseph Attanaseo
what happens if another user logs on to that machine ? does the issue still happen ?
Timothy Hickman
Main: 877 627 3772|
Thank you, Barry! I haven't yet confirmed with the user, but I recreated & solved the issue on my end.
I would love to say I recall noticing but I don't think it occurred to me. Appreciate the feedback!
Joe
SOFTWAREProjectWise Explorer: 10.00.03.334Power InRoads 08.11.09.918Power GeoPak 08.11.09.918OpenRoads Designer 10.09.00.91OpenRoads Designer 10.10.21.04OpenRoads Designer 10.12.02.04
SPECIFICATIONSDell Precision 3630 Tower (Win 10 Pro 64-bit)CPU: Intel Core i7-9700 @ 3.00 GHz, 3000MHz (8 Core, 8 Logical Processors)RAM: 32 GB, 2 x 16 GB, DDR4, 2666MHz, DIMMGPU: NVIDIA Quadro P2200 w/5 GB GDDR5XSTORAGE: M.2 2280 512GB, PCIe x4 Gen 3 NVMe 1.2.1
Thanks for chiming in, Timothy! Had Barry's result not worked, logging in directly would be the next step. Thank again for your help!
