Hi all
Have you the same problem that I have noticed lately?I have problems with my connect version and the problem is the speed/response time that really has gone slow, I don´t know if this has to do with Acad 2023 combined with Microstation Connect edition Version:10.17.01.58 but something has happened. This is most when I have an civil Xversion DWG file as an referens file to microstationwhen everything inside Microstation is taking loooong time to process.
I start the question with this word to see if someone else has noticed the same problem.
regards
Tom
And PSIf Oto:s suggestion is working I wote that Bentley is at least testing it, it would be great if we as microstation users did have the same "speed" when reading dwg files as ACAD usres //Tom
Makes sense, my understanding was that you got a performance drop after installing acad 2023. If that was not the case then the object enabler cannot be the cause.
Mark
Answer Verified By: Tom
Ok Mark
I didn`t know either, ACAD is pushing out updates and I install them, This problem could been within older ACAd versons (most likely) but versiaon I had at the moment I noticed this issue was ACAD 2023.
Best regards
