Hi
There is an huge bugg whithin xml surface model import.
Example files:
Tunnel in dxf referens (or import, the same result)
The same information in surface xml and imported to microstation is not good (bugg)
Lok at the sides of the tunnel in image, these are totally wrong.
Microstaion version:
Version:10.17.01.58
AND
PS Mark
The elements imported from surface XML are NOT imported as mesh, they are imported as shapes
//Tom
correction
I checked the dgn file after the import of XML surface and it is n´NOT creating shapes.
Microstation is importing it to an TRM object (for some reason) and then this makes some sence why this is going wrong from the beginning!
If the land xml import had two options, one to create TRM information as microstaion wants it or import the land xml as shapes (or mesh) then this would work as I want and give more user options to resolve problem areas (scanned tunnel model, ground model, building model9
yep, heres what i see in Vanilla Microstation:
Mark
Hi Mark
If you search for import of XML files you dont find it where you looking.
The import is here:
Your link is the same as this above, no different'
The same dialog box is appearing
Tom
Do you have any example to share?If the triangles are already generated in XML then there should be some way how to import it as mesh and not terrain.LandXML can contain points and triangles it is true.
