Hi
There is an huge bugg whithin xml surface model import.
Example files:
Tunnel in dxf referens (or import, the same result)
The same information in surface xml and imported to microstation is not good (bugg)
Lok at the sides of the tunnel in image, these are totally wrong.
Microstaion version:
Version:10.17.01.58
Hi OtoHere is an example:
test_moved_XML.zip
And to view the tunnel you can reference this ifc file of the same information as the XML is:
test_moved_IFC.zip
Tom
Here you go. VBA macro which allows to select a LandXML file for import and imports it as triangles. Beware it is slow to import using VBA so have to wait couple of minutes. Added also a progress bar to at least get some feedback.
As VBA doesn't have API for mesh creation then need to later convert triangles to mesh using mesh tools.
import-Landxml-mesh.mvba
Millions of thanks Oto!
I test your VBA as soon I have the time, what I suspekt when you wrote that is slow is that I probably can´t have it as my day to day workflow BUT you have created something that Bentley should have as an option in XML import function.
Bentley has the new Open tunnel design software but I don´t think that Open Tunnel can take care of "as built" tunnels. It is sad that you can not take care of your whole project cycle with Bentley produkts, you can design but not process "as built" material.
PS
The software that I use to handle the "as built" scanned data and from where I exported the test material was from Cyclon 3DrLeica Cyclone 3DR | Leica Geosystems (leica-geosystems.com)
Example in file sizes of the scanned/meshed tunnels:
Example size (dxf)
Max size that we allow is 200 mb (dxf):
But there is bigger file sizes that we need to check and plan how to make them smaller
XML file is loading 80% faster to softwares than dxf, xml is also mutch faster to deliver via internet than dxf, so thats is the reason for trying ton use XML as an "workfile format" And if there was a way to import xml triangeles as mesh you save more time, to exchange dxf "shapes" to dwg mesh is taking a lot of time when triangel summary is over 400000 and biger than that it tkes hours.
This examples above is skanned lenght from 0-50 m and the largest is about 200m long, take this times 4000m x3 paralell tunnels you can getthe amount of data that we have to handle
All the skanned data needs to be delivered as dwg mesh,, this is our main problem.thT i try to solve inside microstation.
//Tom
Bentley is interpreting that TIN doesn't allow meshes with overhang and converting it to DTM. This is not correct as TIN only means it is triangle mesh not that it is DTM.https://communities.bentley.com/products/3d_imaging_and_point_cloud_software/f/contextcapture-descartes-pointools-forum/217981/landxml-data-for-sandvik-driller-s-office/666138#666138Why not use OBJ format?
