[MSCE U17] Adding filter to report returns nothing
I'm sure this worked before.
As soon as I add a filter, in this case a level filter, the report returns no rows. If I remove the filter all rows are returned.
Have I missed something? I'm I getting crazy?
I've attached a small example.
Krister
3750.test.dgn
  • I apologies for the confusion.
    I verified this issue in MS 10.17.01.58 and it is found fixed there.
    And MS 10.17.01.58 is already released version. Please see the attached video for your reference.
    Abhay
    Answer Verified By: Krister Surell
  • By chance is there a hot fix for OpenRoads Designer to solve this issue?
    OpenRoads Designer 2022 R1 |  MicroStation CE Update 17  |  ProjectWise CE 3.434
  • Turns out if you update/add the report filters in the latest version of MicroStation, ORD will be able to use them.
  • Hi Jack,
    The next release of OpenRoads Designer will consume MicroStation 10.17.02.454 which contains the fix mentioned above that is available in MicroStation CONNECT Edition Update 17.17.01.58.
    I recommend following the OpenRoads Communities Announcements Forum for updates on when the next version will be released.
    Tamicca Sellars
    Product Manager I
