I have created various short cut in MicroStation V8i in my PC. I need to transfer all these short cuts to another PC.
Is there any simple way to transfer those short cuts from one PC to another without creating each one in another PC?
Thanks.
Tarun Patel said:Is there any simple way to transfer those short cuts from one PC to another without creating each one in another PC?
While it's possible to copy your shortcuts to another PC, keep in mind that MicroStation is designed to work in a network. It is designed to let you place resources (e.g. function key shortcuts) on a server so other computers can use those resources.
It's done through the magic of configuration variables (MS_FKEYMNU is a configuration variable), which you define in configuration files. See this help topic. Configuration concepts are the same in V8.
MS_FKEYMNU
