I have cells in my drawing that are probably connected to the base and cannot be deleted or modified, which I have to set to be able to modify and delete them. How to unlock them, I don't care about connecting to the base
MicroStation V8i SS1 is a rather old version of MicroStation: see the History of MicroStation.
Mateusz Czajkowski said:I have cells in my drawing that are probably connected to the base
What do you mean by 'connected to the base'?
because there is ODBC information in the raw data / linkages clicking on the information about the element does not show the cell but the
cell:infrared feature: CELLNAME
Mateusz Czajkowski said:there is ODBC information
OK — the element has a database (DB) linkage.
Mateusz Czajkowski said:I don't care about connecting to the base
You can modify or delete an element that has a DB linkage. That linkage doesn't lock the element.
However, when you delete such an element the DB will retain the information about that element.
Your first screenshot shows that the element is Unlocked. You can modify or delete the element.
yes it is unlocked but shows an error when trying to modify it:
Mateusz Czajkowski said: it is unlocked but shows an error when trying to modify it
That's not normal MicroStation behaviour. Another app. may be required to manipulate your elements.
I'm working a new microstation file. The cells for this new drawing were copied from the reference, which is also a dgn file, but I got this file from an outsider.
