Perhaps my question is silly, but I cannot find the workaround to config the beginning elevation of contour. It lets you to set Major and Minor Interval only.
Anyone knows the solution?
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
clever_anthony said:I cannot find the workaround to config the beginning elevation of contour
I don't see the contour properties dialog in MicroStation Help.
I'm thinking you might be referring to old Terrain modelling tools that were available possibly in Triforma or ABD. The following discussions relating to this show you might be thinking of an Elevate Terrain tool that was previously available. I would not think this type of operation could be performed in MicroStation CONNECT Edition but may be something that could be achieved in OpenRoads or OpenBuilding.
Has the Terrain modelling feature been removed from recent updates?
Terrain model tool in XM version, where is it in AECOsim version?
Jon Summers said:I don't see the contour properties dialog in MicroStation Help.
Jon,
Here's a link to the Descartes Help discussing Contours as it relates to Scalable Terrain Models. This is equally applicable to the Contours property of Terrain Models in MicroStation Connect.
It really should be in the MicroStation Connect help as well, since Terrain Models are now supported in MicroStation CE.
Regards,Ron
Andrew Bell said: I would not think this type of operation could be performed in MicroStation CONNECT Edition
Do you agree with Ron Jones that this Descartes functionality is available in MicroStation CONNECT?
I am not going to edit the Terrain model, and I just want to change the display of contour lines.
e.g.: I would like to see the contour lines (0.5m interval) in 8.3m, 8.8m, 9.3m, 9.8m, along the soil nail's designed elevation.
However, the Terrain model can only show you 8.0m, 8.5m. 9.0m, 9.5m, 10.0m.
Jon Summers said:exact version no. (e.g. v10.x.y.z)
v10.17.00.209
