Hi, Dear All,
I defined and activated an ACS. However, when I click front view button, the view still rotates according to the original CS. Could you please advise that what I need to do to make the View Rotation Tool Buttons follow the defined ACS.
Dong
You can check ON the ACS Plane Lock, then View will be rotated based on the active ACS.
Answer Verified By: Dong Wang
Wiki For your Reference, Guess you can read :)
https://communities.bentley.com/communities/other_communities/chinafirst/w/chinawiki/26843/acs
