Hi All,
Any way(s) or VBA to annotate the properties of Item Types for each exiting element in the DGN model? similar to Display Text: ON in tagged elements.
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
Jing Jing said:Any way(s) or VBA to annotate the properties of Item Types for each exiting element in the DGN model?
It's not clear what you mean by 'exiting element'. Do you want to create a text label that includes the value of an Item property? Please post some screenshots or, preferably, a DGN file that illustrate what you want.
Thank you Jon.
The MicroStation we used is 10.17.01.58. And below is the sample of 4 points that with item types. We want the properties of item types being labelled next to those points.
jing jing (o'.'o)
Jing Jing said:We want the properties of item types being labelled next to those points
The way to label Item Type data is to use a text field in a text, text node or cell element. When editing text, you have the option to insert a text field that connects to an element. If that element includes Item data, you can pick one of those properties to display the data. Your text may include one or more text fields, each displaying a different element property.
Post a DGN file that includes your Item Type definition and tell us how you want to see those data.
N.B. MicroStation has had a different and unrelated technology, enter data fields, for decades. Enter data and text fields are two different technologies. Don't confuse them!
Perhaps the new Item Type Text functionality may help:
New in MicroStation CONNECT Edition Update 17 - Item Types - MicroStation Blog - MicroStation - Bentley Communities
Mark
Mark Shamoun said:Perhaps the new Item Type Text functionality may help
Thanks for pointing out that new functionality!
What's not clear is how the new Text Field is incorporated into a text element. Perhaps Marco Salino could provide a hint?
