I have a cell with text and border around it, generated from a 3rd party for signs. We need to clip the outside border and leave the table & sign inside showing. Is there a way to do this?
SS10, SS4, SS2
Did the cell come from a MicroStation cell library? If so, you could obtain this library and edit the cell there and then perform a replace.
Using The Replace Cells Tool
If you don't have the original cell library, I would think the only other option would be to drop the cell if you wanted edit components of it.
the cell came from a add-on program, GuideSign.
PowerGeopak SS10 v08.11.09.918
Is there any reason you couldn't attach the cell's model from the cell library as a reference attachment then clip as you would any other reference file? Or put the GuideSign created cell in its own model within your DGN then attach that model as a reference and clip? If you want/need to do this to more than one or two cells then I'd copy, drop, edit, and create my own cell and replace like Andrew suggests.
A less elegant solution could be to draw an opaque shape using the background color which would mask what you wouldn't want to see.
Matt
Answer Verified By: Robert Watson
Matthew Eiben said:Or put the GuideSign created cell in its own model within your DGN then attach that model as a reference and clip?
I've done this many times. Not only does it allow me to clip the fabrication specification when I need and easily lay out the sheets of details, I can also use it to place the sign on the plan sheets when needed. With the "Treat Attachment as Element" setting, it behaves exactly like a cell.
MaryB
