From time to time I experience that small acctions makes the file/Microstation to crash.
Today I have had several situations where MIcrostation just crash and disapear. It could be when I press CTRL+F (Save settings) or are moving a view on the sheet. I think it's an errror in the file that makes the program to break down. The question is if it's possible to run a scan of the file in question to see if something is gone bad in it. I mean, the data structure in te file is rather complex, so I could easily understand if an error could sneak into the file.
The problem is that with a bunch of references, added and a bunch of drawing views and and a sheet in the file it aren't a simple task just to start all over again. The file is to complex to just copy the elements from the bad file into a brand one. To redo it all could easily consume the most of a day. With a deadline coming up shortly it's not the thing to spend the time with.
Any suggestions? How do you guys handle situations like this ? Do you experience situations like this at all ?
If it means anything for someone, the Microstaion version is: 10.14.02.01
Thank you in advance
Ole Bro
you can try to use this variable and see if that help to prevent lose data on large DGN files MS_DGNAUTOSAVE https://communities.bentley.com/products/microstation/w/microstation__wiki/24873/microstation-connect-edition-configuration-variables#filesaving:~:text=Description-,MS_DGNAUTOSAVE,-Design%20File%20Auto
Ole,
Earlier this year Regi Wallace and I tracked down a bug with Save Settings. This issue turned up when we were working with reference files and microstation would crash. We discovered that if we had saved settings at some point earlier, a crash would occur while dealing with reference files. we removed the save settings from the automated script and the crashes went away. Defect Report 768377 was created but I don't know when it will be fixed.
Ray
Ole Bro said: The file is to complex to just copy the elements from the bad file into a brand one.
That's the best way I can think of. Start with a clean seed. Attached the file, use the Copy Attachments mode, merge in the main file. All that should be left is to change the reference nesting depths, if any.
Sometimes simply selecting everything and scaling by 1 or rotating by 0 will clear some issues.
I like the idea of scaling the content of the file by 1 and insert it at 0,0,0. I will test this to see if it helps.
Thank you for the tip.
ORD Connect:10.08.01.033
MS Connect: 10.14.02.01
Projectwise: 10.00.03.49
Defect Report 768377 fix is not currently available, although is currently being worked on.
Carl Myhill
Technical Support Engineer
Bentley Systems
