Could you please advise me the way to model rebar reinforcement for concrete by using only MicroStation Connect Edition.
I think ProSteel, ProConcrete or ProStructrure are better, but it's also expensive for small project.
Thank you in advance.
If 3D representation is absolutely necessary, I wouldn't waste my time making it parametric, I would suggest that you do it like this:
For each rebar member type:
To create a symbolic view:
It might be a bit more work than with dedicated packages, but I see no reason why these steps wouldn't give you same kind of output, from MicroStation.
Answer Verified By: Tuan
Thank you so much, Barry Lothian MaryB Johan De Cock
Tuan
OpenRoads Designer CE - 2021 Release 2
(Version 10.10.21.04)
what shame that even after 25 years plus we still cant use multilines with arcs . 2d rebar job would be so simple with your 2 level approach if you could use arcs in multilines , or even fillet multiline intersection , corners and still stay multilines... even roads and footpaths could be used.. but alas not going to happen...another reason I gave up on mulitlines, too restrictive.. having to drop them to do circular fillets....
Lorys
