Hi
I tried but don´t find any easy solution to this visuell/plott problem.
DWG text with background fill, what is this? and can I in microstation avoid the backgroundcolor somehow?
In some cases when dwg file is delivered the text has an filled background on the text and sometimes it do not have it. What is this background and how can I get microstation to read the text as normat text (without the background fill)?
Is there an easy way to handle this in microstation woithout changing the source dwg file? this issue is related on active dwg file or dwg as an referens.
Example
dwg open in Acad 2023:
same file opened with connect edition:
PS, this is an titleblock but the same issue can be in normal drawing/model.
Best regards
Tom
Hi LorysThe backround is not visible in print only in design mode.And the preferences setting work to fix this design issue.//Tom
Hi AndrewThis will also work (I have not tested it), now I have used the preferences solution and it works and it is the same thing...//Tom
Hi FrankThanks for the example files.
The problem is solved for me with yhe preference setting.//Tom
Then we now know, your are working with text fields not text with background fill
Frank
