I have an internal client, exchanging files with a bureau that distributes its files in DWF-format. I can see them via online viewers, like https://sharecad.org/ and https://viewer.autodesk.com/
I get an error, loading them into Bentley View (up15)
What do I do to read, maybe convert those files, short of installing AutoCAD?
VIVAQUA - vdj said:How can I open DWF files in Bentley View Connect?
DWF = Design Web Format. See this article about DWF. It's AutoDesk's proprietary format. MicroStation can't import a DWF file.
VIVAQUA - vdj said:What do I do to read, maybe convert those files, short of installing AutoCAD?
Ask for the original DWG files, which MicroStation can open without conversion.
a quick google search found this on autodesk website...
You can use the program to create Design Web Format (DWF and DWFx) files. A DWF file is a 2D vector file that you can use to publish your drawing on the World Wide Web or an intranet network. DWFx files are based on the Microsoft XPS Document format. Each DWF file can contain one or more drawing sheets.
DWF files can be opened, viewed, and plotted by anyone using Autodesk ® Design Review. With Autodesk Design Review, you can also view DWF files in Microsoft ® Internet Explorer 11 or later. DWF files support real-time panning and zooming as well as control over the display of layers and named views.
so you dont need acad to view
Lorys
