Can't Access our Company Network Drives
Good Day,
I have not yet experienced this issue before.
I am unable to access out network drives once PowerInroads is open, and can also not open a dgn from the network. Keeps asking to select the application but it does not show Bentley Microstation as an option.
Please can someone assist?
  • I don't know anything about your setup...If you are working in the office, or are working remotely...How your software is configured...
    Could you please tell us what specific version of MicroStation/InRoads you are using? - that looks like V8i, but there are several versions of that. Specific version numbers are most helpful, but even SS2/SS4/SS10 tells us something.
    You're right - I don't see network drives listed there. Do you see them in Windows Explorer? What version of Windows are you running, and have there been any updates recently?
    I know that my MicroStation can't "see" my network drive if I am working over a VPN, and have not used Windows Explorer to "open" the drive first. I always have to got to explorer, just browse to my network drive, and then MicroStation will recognize it. I don't have that issue at the office where I am hardwired in.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Hi There,
    Thank you for the reply. Herewith additional information.
    I did uninstall the software this morning and reinstalled it.
    I am working at the office so no connection through VPN.
    Power InRoads V8i (SS10) Version 08.11.09.918
    Through windows explorer all server drives are visible.
    I did a test this morning, if the dgn is saved onto my desktop I can open the file but if I go onto any server and try open the dgn it says file can't be found. Tried the same on another works station and it works fine.
    I did do both test with the software "Run as Administrator" ticked on and off.
  • At this point, you may need to get with IT or Bentley Support to troubleshoot.
    Can you access other network files with other programs (Word, Acrobat, Excel)?
    MaryB
  • Tried the same on another works station and it works fine.
    Well that is pretty indicative that its a faulty install or broken or faulty local preferences.. you need IT dept to completely remove microstation including registry and custom files and  folders and do a full reinstall
    Lorys
    click link to PM me
Reply Children
