Good Day,
I have not yet experienced this issue before.
I am unable to access out network drives once PowerInroads is open, and can also not open a dgn from the network. Keeps asking to select the application but it does not show Bentley Microstation as an option.
Please can someone assist?
Megan Loock said:Tried the same on another works station and it works fine.
Well that is pretty indicative that its a faulty install or broken or faulty local preferences.. you need IT dept to completely remove microstation including registry and custom files and folders and do a full reinstall
Lorys
In addition you may want to review the information in the following article:
communities.bentley.com/.../mapped-network-drives-not-available-in-microstationinroadsmxgeopak
Thank you David, followed the steps and it seems to have resolved the issue I had.
