I have a 3D linestyle that does not seem to render properly. See images below. The Rail Linestyle is on the same level as the Block in the drawing. Int the wireframe view it appears good, when rendered in i.e. Smooth or illustration etc. it does not pick up material and the guardrail itself appears to be wireframe. The guardrail beam itself is "Smart Surface" according to the properties, (is that a mesh?) there seems to be ongoing issues with meshes in linestyles. The post is an extruded sold and it does not seem to render. Is there a color or display setting in the Linestyles to fix this?
The surfaces and solids used to create the linestyle render properly before used to create the Linestyle.
Using MicroStation update 17, windows 10 Enterprise.
Hi Oto, the mesh option work. When you create IFC files does your 3D line stile export. I have tried to create a solid but it seems like the style need to be a feature definition.
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
Yes this is know issue which should have been resolved ASAP but is not. For example OpenRoads heavily utilizes 3D linestyles which are undocumented feature with lot of issues.
