I often use the keyin "clipboard pastespecial Text To Design File" (which i have on a function key) combined with "clipboard cut" to cut and paste text rotated to current view. In V8i this worked fine but in Connect (Update 17) all pasted text appear on the level "Default". I want it to be on the active level.
Is there any way around this?
Thanks!
There have been several threads about different element types showing up on the Default level when they shouldn't...So this doesn't entirely surprise me.If nobody has a setting or a fix, it may be worth filing a Service Ticket with Bentley Support.
MaryB
Why don't you just open the text editor and paste the text into there? When you paste the text in the editor select Paste Unformatted so it uses the active level & text style. It's essentially the same process other than you are opening the text editor.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
The process would get more complicated if I need to use the editor since I use this method to fix hundreds of texts. Now i just press F8 and F9 on the keyboard (I've made function keys from the keyin).
This is reproduceable and is different behaviour from V8i, Bug 1056465 has been raised.
Kristoffer Becker said: I use this method to fix hundred
So you are replacing incorrect text? If so why not use the replace text tool?
