make raster reference to look like the reference dialog
I wish the reference raster file dialog were laid out like the reference file dialog using the same icons
Better yet have them both use them use the same icons as the element manipulation tools Move Scale Rotate, and Mirror
  • I often found new users  load the wrong  manager and having them look different  made it easier to realise its the wrong  tool, but combining the two with a submenu option just for rasters and use the same icons would be  best of both worlds
    Lorys
    click link to PM me
  • I would like to see tools be intuitive. If its a 2d element then you get 1 set of choices. If its a 3d element you change it to allow 3d manipulations
    For example
    Modify tool in 2d could also be used in place of the 3d modify entity
    extend tool in 2d could also be used in place of the 3d modify entity
    Insert vertex  & delete vertex be capable of adding or subtracting from a linear solid
    Chamfer and fillet  goes without saying
    Copy \ move parallel  would be able to work with linear slabs
    Trim to intersection could extend and intersect  3d objects this would act like unite solids with the added ability to extend
    Kirk
    I Wish Cadland was Reality
  • I just ran into an issue where I could not login to the forums. I submitted an SR to find out Bentley did a major update and because my forum email was different from my licensing email my profile was not longer working. When I first joined the forums my firm had one email address format. Later on they introduced a new address format. When we went to federated licensing my administrator used the newer email address. Bentley linked my email addresses so I would not loose my training transcripts for the LearnServer.
    You may need to submit an SR
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • Isn't it already consolidated under Explorer?
