I can't find the post where this was answered before.. I had a keyin code that would rotate 90 degrees and keep cycling through. It was something along the lines of:
ActiveSettings.Angle = ActiveSettings.Angle + Pi / 4
I usually keep this in a function key, but have since lost it.
but i can't figure out the exact syntax for keyin on V8i Select Series 10
Hi Cole,
Review this thread and see if that is what you were looking for, the key in was provided under MicroStation Programming Forums by Barry Lothian Cell Placement angle scroll
l
