Hi everyone,
I saw a few posts that explained how to export the models in a dgn file to seperate DWG files
https://communities.bentley.com/products/microstation/f/microstation-forum/171130/export-file-with-multiple-models-as-seperate-files/492329
, however I was wondering whether it's possible to save a dgn file with multiple models to seperate dgn files instead.
Joy & All,
I have searched for this same solution as well. Bentley has created a set of applications which includes a model exporter, LastMileUtilites. I have downloaded and run it several times to export sheet models successfully, though lately it has stopped working for me. I am guessing I changed a setting in my workspace, need to sort that out.
Meanwhile, I have downloaded Jon's utility and will be putting that to use very soon! Thanks Jon!
Here are links to see the description, the download post, and a help document.
Last Mile Utilities - Set of utilities for OpenRoads & OpenRail Designer
Last Mile Utilities v2.1 for OpenRoads Designer
Last Mile Utilities v2.1 Help
Mike Nelson
dodis said:Bentley has created a set of applications which includes a model exporter, LastMileUtilites
From the Bentley Wiki page you cite: LastMileUtilites does not work on MicroStation as it uses classes from OpenRoads Designer SDK.
In contrast, the VBA utility I wrote is based purely on MicroStation.
True, caught that after posting. And since I broke something in my WorkSpace, I intend to run your utility instead! Thanks for the reminder, for all.
Mike
Well, I am still stuck. Still can't get LastMileUtilities to work, and your utility won't work with OpenRoads files either, at least not cross section sheet models.
When running the utility, when it wants to delete the unnecessary models in the output file, gives this error and cancels.
"You cannot Detach or Delete the ThreeDSpace of the active model. The operation is cancelled."
I do know there are several output methods for generating cross sections, but other than creating everything in the current file just locks up my ORD right now. I have a service ticket in and will be reloading ORD (or upgrading if available) tomorrow.
Thanks again!
As has been suggested by Jon Summers, as these utilities you are having issues with had been produced and programmed specifically for OpenRoads and OpenSite Designer it would be suggest that you should be asking your question in the Communities page relating to that software. This is the MicroStation Communities Forum, and we would not have any knowledge of these tools or getting other VBA code to operate in this other Bentley software.
OpenRoads | OpenSite - Bentley Communities
dodis said:Can't get LastMileUtilities to work, and your utility won't work with OpenRoads files either, at least not cross section sheet models. When running the utility, when it wants to delete the unnecessary models in the output file, gives this error and cancels. "You cannot Detach or Delete the ThreeDSpace of the active model. The operation is cancelled."
I don't have OpenRoads. The utility was developed and tested with plain old MicroStation. The OP seems to like it.
The message you see indicates that OpenRoads locks ThreeDSpace (whatever that is) to prevent its removal. ThreeDSpace is not part of MicroStation. Presumably that's one reason why the OpenRoads developers created LastMileUtilities. Post questions about LastMileUtilities in the OpenRoads Forum.
