How do I get it so my DOT workspace can be selected without it freezing up?
Not necessarily. It's entirely possible that the actual CFG file has paths that reference to the Organization-Civil folder structure. You could copy the files into the Organization folder, but the path variables would still refer to the ...Civil folder structure, which would be missing.
Would you be able to share a screen shot of your MicroStation ...\Configuration\ directory structure, and the contents of your MicroStation WorkSpaceSetup.cfg file?
MaryB
Thanks all - I was able to solve this. I had not downloaded all of the files from NYSDOT, otherwise the above solution worked for me.
