[MicroStation 17.1 and ORD 2022R1] Dim style change do not activate text frame
Changes in dim style e.g. by adding text frame (any type) for notes are not reflected on existing notes nor after applying Change Dimension. Same issue when element template definition is changed by assigning different dim style that has text frame for notes.
Is this a know defect and has anyone a workaround?
Please do not move this to ORD as this issue seems related to MicroStation / Power Platform
Mariusz
